-   -   7mge inefficiencies (http://www.toyota-supra.info/forums/mkiii-supra/18015-7mge-inefficiencies.html)
907mge 10-22-2010 01:05 AM
A chevy 350 is 5.7L almost double that of the 7m and a 454 is 7.4L. Plus there are tons of aftermarket mods for chevys while a 7mge has far far fewer. And by the time you put in a stroker kit and cams to build a high strung 7mge you could of bought a JDM 2jzge and left it stock with far better reliability and more hp and torque.
zby67 10-22-2010 07:43 AM
i thought about doing something like that but what are the mods do you have to do to get the 2jz in the MK3?
bioskyline 10-22-2010 07:46 AM
its the same as swapping the 1jz in. the 1jz and 2jz are the same block (more or less) do a search details are on here
zby67 10-22-2010 08:07 AM
thank you will definitely do that. just was trying to take easy way out and hoping someone would post a link lol.
seth959ci 10-22-2010 04:45 PM
so will raising the CR to about 10:1 or 10.5 really give me much of a hp gain? or will a ported head result in a larger power increase?
Grandavi 10-22-2010 05:04 PM
The only replacement for cu.in. is technology really. That's the main reason the turbo has an advantage. The 7M is a pretty old engine (remarkable how well they stand up though). I look at headache + cost + end gains when I research this area. To my knowledge, the least headache and most cost effective way is to get a 1JZ swap (providing you have everything needed before you begin). So many people talk so much about it on the forums that I sometimes get complacent and assume its easy just becuase it is such a common topic. But mapping it out you find there is a ton of "little things" to know before going in.. and I always find one more little thing.
I have never owned a more expensive car to fix properly.. lol. but.. then again.. im being fussy and usually end up buying "near perfect" or new parts only.
87hilux7mge 12-22-2010 11:37 PM
bumping up compression will give you id say about 15-20 hp if lucky, and not at the wheels. u have to get into the 12-12.5 range to see some real gains, and then you stress your entire motor. rings, bearings, valve train. ud wanna look at upgrading rods (not a bad mod neway) and have custom pistons made.
PnP the cylinder head is a fairly easy venture, its just time consuming. i spent 12 hours just on the bowls and short side radiuses. i didnt get crazy on the ports much but cleaned up alot of casting flash and tapered the guides. if you look at flow charts a full "street port" give you a bump in flow from 179cfm@ .30 lift to 201@ .30 lift. mine flowed 198 (+/- 1 cfm on all ports) at .30 and 28". overall i spent about 24-26 hours of straight work on mine, not including valve polishing and lapping. plus i have the stage 2 cams to put in now so those numbers could change.
im hoping to crack the 200 mark with this setup on my GE, b4 i get my sc on there.
bored/honed/decked block (50mm over, .010 removed)
PnP head, resurfaced (.008 removed)
BC stage 2 cams, 268's
adj. cam gears
comp valve springs
NPR pistons, rings (50mm over) balanced (+/- .5 grams)
king main bearings, std size
micro polished crank, std size, balanced (zero balance)
eagle H beam rods, balanced (+/- 1 gram)
ATI super damper
SDS EFI engine management system
mind you this will be in an 87 4x4 pickup with 32" tires.
after the supercharger, depending on pulley, i should be able to hit anywhere from 240-low 300s.
ill post dyno #'s for both n/a and SC form, but it will be a few more months still its done.
BTW, those stroker kits are garbage IMO, i have looked and looked, talked to lots of supra guys, and so far i havent found one thats ran or still running. the 7m motors are stroked 5ms and its pretty well maxed out. lots of custom machining needed. all for maybe 40 hp over stock, so on a proper rebuild, a scant 220-240 if very lucky. thro in the parts that ive invested in, and you might get 260-270, and about 10k spent (stroker is over 3k alone) for something that has the likely hood to fail due to stressed components.
