#1 |
This is stupid question time... but my 88 is a 7MGTE and bone stock except the rad (got it while I had coolant changed, is the KOYO aluminum one). No 3" exhaust yet, although I have 2 available on my donors. Boost is stock, the only addon related to the engine is a turbo timer (just using it for cool down).
So.. I have questions. First, I own a 87 that has a really nice 3" exhaust and Megan DP on it, boost controller and the waste gate is shimmed I believe. I get a whistle when I start out which I thought was initially the fan belt, but now I think its a vacuum leak. Did the previous owner shim the waste gate for faster spool? (all the cars I own btw are 7MGTE) Second, to begin with, all I think I need is a boost controller (would be nice to have a boost gauge to put inside the car as well) to up the boost from stock to 10-12 psi. Correct? The 3" exhaust is a given so I wont discuss that yet, unless there is something relevant that I should know other than it lets the car breathe better... I dont need to focus on the FCO (adding Lexus AFM, 550 cc low imp injectors, or fuel pump) unless I go with a larger turbo. Correct? The stock BOV is fine, or should I upgrade that? (not sure if its needed for performance, looks or sound ..) Finally.. I have a JDM Supra JZA70 rear-end (LSD), does anyone know the gearing on this? Just wondered what it is compared to the stock one in my 88 to decide if I am going to swap this in or not... Found this... Other features of the JZA70 Supra was the replacement of the mechanical clutch LSD with a Torsen unit. The final ratio was also changed to 4.11 compared to the 3.73 of the MA70.. so now I have to go look and see what mine is on the 88... probably the 3.73. Not sure which is more desirable.. (going to read now.. ) Thanks in advance!
My Links: What I am doing... http://www.toyota-supra.info/forums/...part-list.html My questions http://www.toyota-supra.info/forums/...w-answers.html Last edited by Grandavi; 10-22-2010 at 06:57 PM. |
Thread Tools | |
Display Modes | |
Stock MKIII | 2Fast2Furious | MKIII Supra | 13 | 04-14-2010 06:34 AM |
question about the stock BOV on a MKIII Turbo | TehEl1te | Non-Generation Specific Questions | 3 | 08-23-2009 10:20 PM |
1993 BMW CI vs stock MKIII supra | west_side_supra | MKIII Supra | 2 | 04-15-2007 09:24 PM |
93 BMW 328ci versus a stock MKIII turbo supra | west_side_supra | Road Racing & Autocross | 1 | 04-14-2007 01:20 PM |
