Old 10-25-2010, 02:17 AM   #1
Sonyps307
Default Arp studs or bolts
Im looking to get a set of arp bolts or studs for my head so do they both have the same strength or is it just easier to install the head with the studs
Old 10-25-2010, 02:34 AM   #2
89ST
89ST is on a distinguished road
I used arp bolts and they seem to work just fine
89ST is offline   Reply With Quote
Old 10-25-2010, 02:47 AM   #3
Sonyps307
Well my motor is going back the shop cause they messed up the rebuild and I was just going to get some new Arps and have them torque to 70lbs the first time they torque them to 58lbs
Old 10-25-2010, 07:46 AM   #4
bioskyline
bioskyline is on a distinguished road
the studs are suppose to be better, but they came out with bolts for applications where studs cant be used, like in v block cars where tight clearance wont allow head removal in car if on studs. both are made from the same material though.
87 silver turbo targa, bone ass stock (for now)
bioskyline is offline   Reply With Quote
Old 10-25-2010, 08:34 PM   #5
MJG
MJG's Avatar
Bolts or studs, can't go wrong with any of them.
ARP recomends 75LB-FT torque for aluminum heads.
If you have your block milled for a MLS head gasket, the lone alignment dowell at the front of the block must be removed. I used the studs the last time around. This worked to align the head to the block, eliminating the need for installing a new dowell.
If your interested, I have a set of used ARP bolts / washers for the 7M. Used once, torqued to the 75LB-FT value and in great shape.
Bolts? Studs? Blackdog MKIII Supra 9 01-12-2010 06:42 AM
7M-GTE Head torques on stock bolts... MA70-3.0GT MKIII Supra 2 11-07-2009 04:58 PM
ARP head bolts or studs? mirage83 Non-Generation Specific Questions 0 03-19-2008 10:09 PM
Head Bolts, Or Head Studs?? ZauggIt1 MKIII Supra 2 08-08-2006 01:23 PM
ARP Studs or Bolts ?? Bullz_EyE MKIII Supra 10 10-26-2005 01:49 PM
