Do i need to remove the intake to install the wiring harness when lowering the engine into the engine bay ? I bought a jdm engine and removed the cut off harness from it but i took off the intake to access it easily. So while its hanging on the hoist close to all the way down, is that the way to do it?
thanks dave |
Should have left te harness on the engine and disconnected it from The ECU
I think it's easier to take just the pipes and not the whole intake to run the wires
Thanks soo much for your response, this will be the first of many questions to come if you guys don't mind..
I will disconnect the ecu as you suggested |
