Old 10-28-2010, 01:06 PM   #1
scherp420
scherp420 is on a distinguished road
Default mk3 bad fuel
i recently belive i put bad fuel in my supra and i think that is why its not running correctly. it runs but rough i need help i think i might need a new fuel pump now?
scherp420 is offline   Reply With Quote
Old 10-28-2010, 01:21 PM   #2
johnvin
johnvin is on a distinguished road
if you have bad gas the only way to get it out is if you jack it up and drop the tank and empty it and clean it out good! but also i heard that when it runs like that some guys put sea foam or heet in the gas
johnvin is offline   Reply With Quote
Old 10-28-2010, 11:32 PM   #3
scherp420
what if i disconnected the main fuel line and started it to drain all the gas out into a can or something? but wouldn't that be bad for the starter?
No Fuel Pressure Wong Wei MKIII Supra 6 05-16-2010 03:03 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
