-   -   q45 throttle body 90mm will fit on.... (http://www.toyota-supra.info/forums/mkiii-supra/18100-q45-throttle-body-90mm-will-fit-on.html)
fantasma87 11-02-2010 11:07 AM
that throttle body will fit on a stock 7mgte engine? any mods?
cre 11-02-2010 01:10 PM
No, it won't fit the stock intake plenum.
fantasma87 11-02-2010 02:25 PM
the mount its bigger ? if i get a front face intake it would? but the connectors "plugs" are the same? thanks CRE for the info. :bigthumb:
cre 11-03-2010 02:45 AM
No, the plugs are not compatible. You'll need to get an electrical connector for the Q45 and then you need to rewire a couple things for it to work. No, not all FFIMs accept the Q45 TB... there are several popular throttle bodies used on FFIMs and you'll need to choose the TB accordingly. The Q45 is probably the post popular choice though, but make sure before buying.
The wiring details have been posted here and at supramania and supraforums a few times in the past. It shouldn't be too difficult to find with a little searching.
