Old 11-17-2010, 05:09 PM   #1
slowmak55
slowmak55 is on a distinguished road
Question MOVED: throttle rod
i have a 87 toy supra non turbo. the throttle rod has been adjusted . the book says that it should not be adjusted!! so how do i reset it back to factory setting ??? help!!!!!!!
slowmak55 is offline   Reply With Quote
Old 11-17-2010, 07:51 PM   #2
This doesn't belong in the FAQ. Thread moved.
If you're talking about the linkage that runs from the pulley assembly to the throttle body, adjust it for about 2-3mm of play; then adjust the throttle cable as detailed in the TSRM.
Old 11-17-2010, 10:01 PM   #3
slowmak55
Default dashpot rod
thanks for your quick reply. it goes from the throttle body linkage (dashpot) to the cruzecontroll cable and throttle cable mounted on the valve cover-mounted bellcrank assembly. thanks again. i think its called dashpot act. it opens and closes the dashpot diaphragm.
Old 11-17-2010, 11:25 PM   #4
Yeah, we're talking about the same rod. I don't recall ever reading a spec for it, 2 to 3mm is average.
lost of power at full throttle?? peedamonkee MKII Supra 4 01-08-2008 05:50 AM
Jdm Throttle Body Luvs2slide MKIII Supra 1 07-24-2006 07:15 AM
Throttle response f00g00 MKIII Supra 1 04-13-2006 12:57 AM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
throttle body boogum7 MKIII Supra 5 12-21-2005 03:01 PM
