I have an 87 non turbo the steering is tight/hard to turn and suddenly frees it self and works normally.Was leaking,high pressure line changed a few months ago,but has been erratic,any suggestions?
have you checked your power steering fluid level? sounds like it's low....
Thanks for the response,right now I have garaged car and seriously considering swap to 7mgte and 5 speed tranny,dont have the time right now work seminars is taking priority
Bone Stock w Upgrades ;-)
Check the belt tension. It could be slipping intermittently causing the weird steering feedback. Also check the belt condition and if it's polluted with oil.
No power steering | 90supra | MKIII Supra | 1 | 11-01-2010 01:17 PM |
Power Steering cables wet (leak) question | rjSupra | MKIII Supra | 2 | 09-20-2010 11:34 PM |
87 nonturbo power steering leak | jchaske | Non-Generation Specific Questions | 0 | 01-23-2010 06:01 AM |
Power Steering?!? | Boombastic | Drifting | 5 | 05-19-2009 04:19 AM |
Power Steering Pump Pulley | trevor217 | MKIII Supra | 4 | 05-17-2009 08:28 PM |
