Old 11-13-2010, 04:16 AM   #1
ochowdero
Default ruff start!
soo
when i start my car, cold start or hot, it will sometimes idle ruff and shut off.
specially when i am trying to back out of a parking spot at the crowded mall
this isnt good..
this is the only time my car will do that, (right when i go to start it)
soon as i get it running its fine.. even when im idling at a stop light.
whats the problem?
i thought it was a vacuum leak, I.E my bvsv, which was cracked. so i bypassed the vacuum hoses til i got the new bvsv and hooked it up and it still does it..
so what can it be?
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Old 11-13-2010, 11:45 PM   #2
Check for diagnostic codes. Test the TPS alignment when cold and when hot, particularly the IDL switch. Test, inspect and clean the ISC (idle speed control) valve. Check to see if fuel is coming from the cold start injector at ay time other then when the starter is cranking... make sure it's clean too and that it sprays when the starter is cranked (read the TSRM on testing it). Lastly, test the air flow meter. The VAFM is relatively easy to test where as it's harder to really know with the KVAFM that the GTE uses unless you've got an accurate scope and know how to use it.
Old 11-14-2010, 04:31 AM   #3
bioskyline
bioskyline is on a distinguished road
one vac line to check is the one on the bottom of the intake pipe to the turbo. this goes to the power sterring pump. mine did the same thing and it was that hose, who every changed the air filter didnt put it back on
87 silver turbo targa, bone ass stock (for now)
bioskyline is offline   Reply With Quote
Old 11-18-2010, 04:29 AM   #4
ochowdero
Default vac hose?
can you post a pic of this hose?
i looked under my hood and not sure what your talking about..
i really want turbo
Old 11-18-2010, 04:29 AM   #5
ochowdero
i was also thinking it could be my timing..you think so?
can i check diagnostic codes my self? or do i need to take it somewhere?
i really want turbo
Old 11-21-2010, 07:43 AM   #6
aamt07
aamt07 is on a distinguished road
I just got done replacing the CPS O-ring on my supra. If the timing is not set exact the car will try to find the best timing electronically. It might be that you need to loosen the CPS and rotate it back and forth to find the right setting on your timing. I would use a timing light the crank pulley should have grooves on outer and inner lips of crank and should line up to 10 degrees.
I had the vacuum line off my intake for about a month until I pulled the intake system off to mess with CPS due to the lack of my mechanic not reconnecting everything back. Thats not your problem but I would want every vacuum line sound its a small hose going from almost directly underneath the Air flow meter you will see a little 90 degree elbow it has a line that goes under power steering reservoir. (between power steering and turbo)
91 TURBO TARGA TOP 5 SPEED PEARL WHITE.... UNDER CONSTRUCTION...
aamt07 is offline   Reply With Quote
Old 11-21-2010, 08:05 AM   #7
aamt07
Default vacuum line
its part number 17341 that connects to 17630
http://www.cygnusx1.net/Supra/Librar...spx?F=1708&P=3
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
87 non turbo wont start, need some advice...please. HotRodV6 MKIII Supra 3 09-02-2010 07:29 AM
Stalling at start up Green7mgte MKIII Supra 4 12-15-2009 06:31 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
