Old 11-23-2010, 12:52 AM   #1
john_lauj
john_lauj is on a distinguished road
Default turbo wont boost
i have a 89 supra turbo and i can boost more than 8 psi. i chime the waste gate to gain my boost. i was at 3 washers and i was getting 8 psi. i went to 4 washers and i still get the same result. is it possible that i have a leak?? if so any idea which hose it can be???
john_lauj is offline   Reply With Quote
Old 11-23-2010, 04:28 AM   #2
Minymurf
Minymurf is on a distinguished road
do you have a boost contoller on it?
Minymurf is offline   Reply With Quote
Old 11-23-2010, 07:38 PM   #3
john_lauj
no. i chime the waste gate to gain boost.
Old 11-23-2010, 08:10 PM   #4
btwilson86
Super Moderator
btwilson86's Avatar
There's definitely the possibility of a boost leak, unfortunately ANY hose can be a suspect hose. Just idle the car and listen around the engine bay, if you hear any air being sucked in besides at the air filter, there's a vacuum/boost leak.
You should really do away with the wastegate shims. Although it's easy and cheap, you put more stress on your wastegate. You can build a MBC easily (and more importantly, cheaply). That way you can adjust your boost as needed without unnecessarily adding more stress to other components.
Turbo Timers and Boost Controllers zuni MKIII Supra 5 05-01-2015 04:59 AM
Low turbo boost Spudboy MKIII Supra 2 05-25-2007 07:02 AM
