Old 09-13-2005, 04:12 AM   #1
MWoz34
MWoz34 is on a distinguished road
Default brake lights problem
a new problem has just occured in my 87 supra. My brake lights stay on and they wont go off. the only way they will turn off is when i pull out the fuse from the fusebox. The fuse is labled stop and it is a 20 amp. I did notice a little black washer on the floor my the pedals. is it possible this came off from my brake pedal?? If anyone has any ideas please let me know......
MWoz34 is offline   Reply With Quote
Old 09-13-2005, 09:22 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
at the top of your brake pedal you will see a little unit with a switch on it which the brake pedal leans against
when the pedal is off it pushes the switch so it knows to turn off the brakes... if it doesn't touch it thinks you are braking
adjust the nut behind the switch so that the switch is touching the pedal when you aren't pushing it
make sense?
Pics of my build.
Do a diagnostic first!
Old 09-14-2005, 03:08 AM   #3
SupraMan1784
SP58GT
stop riding your brake man...those are hte drivers i hate...im just kidding unless its true....(the ninja smiley that disappeared all of a sudden)
Brake Lights zebrahabitz MKIII Supra 2 08-13-2009 06:29 AM
Brake lights not working! lifesnotfair MKIII Supra 18 05-05-2008 11:40 PM
help with brake problem mad_dicer MKIII Supra 3 10-17-2006 12:23 AM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
