Old 11-24-2010, 07:32 AM   #1
Supra Saiyan
Supra Saiyan's Avatar
Supra Saiyan is on a distinguished road
Question 89+ climate control into an 88
I have my 88 supra.. I want to put the 89+ climate control in there.. Is this a direct swap? I searched a bit on the web, and the forum.. I just must not have good searching skills.. I'm sure the info is out there.. Please help..
Supra Saiyan is offline   Reply With Quote
Old 11-24-2010, 09:44 AM   #2
If it's USDM then yes it's a direct swap. The floor+defrost selection won't work but everything else will work fine; If you look at the pre89 control you'll see the option isn't there at all. I can't remember what happens when you choose that one... naturally, the air blows through but I can't remember what vents it does come through.
Climate control (Update w/88 supra) Supra Saiyan MKIII Supra 2 09-23-2010 02:37 AM
Retrofitting a 1989 Supra climate control module into a 1987.. TheRiddler Non-Generation Specific Questions 2 11-04-2009 02:33 AM
Retrofitting a 1989 Supra climate control module into an '87.. TheRiddler Exterior , Interior, and Detailing 0 07-16-2009 05:50 AM
ELECTRONIC CLIMATE CONTROL WHITETURBO MKIII Supra 1 02-12-2005 09:04 AM
