Old 11-24-2010, 07:19 PM   #1
worm611
worm611 is on a distinguished road
Default 87 turbo 5spd rear end questions
Hey guys,
Pretty new to Supras, only know what I read in the past, and I haven't retained much. SO questions :-)
- I read they have 3.90 gears in them, which is ok, is that standard for a 5spd Turbo or did they have other ratios they ofered?
- Independent LSD how much HP can you put to that, I'm guessing this one has close to 400HP.
- With 400 HP and the Independent rear suspension can I run a ET Street tire on that without worry about breaking shalfts?
- Anyone install other rears? 9" rear, 8.8 rear or something?
- What size ET street fit well if you recommend using them.
worm611 is offline   Reply With Quote
