Old 11-24-2010, 09:03 PM   #1
bassboy3313
bassboy3313 is on a distinguished road
Default spark plug valley colver bolts
hey. i was looking at the big 14mm bolts that hold on the spark plug valley cover and the bolt furthest to the back of the engine has a little threaded hole in the middle of it with oil trickling out every once in awhile. is it supposed to have this threaded hole? oil is coming out of it and leaking down the rear of the engine. i figure i could just get a bolt with the same thread and plug it. what do you think?
bassboy3313 is offline   Reply With Quote
Old 11-25-2010, 09:44 PM   #2
It's used to mount a throttle cable support is certain engine configurations... LHS vs RHD, IIRC.
Old 11-26-2010, 10:38 AM   #3
bioskyline
on the non turbo motor a hose clamp bracket is attaced to that, so yes you can plug it
Old 11-26-2010, 06:52 PM   #4
Not on all models.... At least not in US market N/A MKIIIs nor have I seen it used on any turbo models here. If any US models make use of it then it would be automatic transmission specific. There should be no need to plug it as it's nowhere near drilled all the way through... it may be plugged if needed though.
Old 11-26-2010, 09:24 PM   #5
bioskyline
maybe its a canadian thing then?, this head is off my 87 na 5spd.
Uploaded with ImageShack.us
Old 11-26-2010, 09:55 PM   #6
bassboy3313
i matched up a bolt and plugged it for now. we'll see what happens.
Old 11-26-2010, 09:59 PM   #7
Ahh, a support for the heater hose! Never seen one of those.
FOUND IT! 87263-14170 it's an 89+ in the USDM parts catalog. Same location is also reportedly used for one configuration of throttle cable bracket but I don't recall ever seeing a photo. Regardless, the hold shouldn't go all the way though but you're free to plug it if need be.
spark plug valley cover removal bioskyline MKIII Supra 6 11-14-2010 07:32 PM
spark plug? BlueTuner MKIII Supra 8 05-09-2010 11:21 PM
Spark plug wires Quik Q carfanatic89 MKIII Supra 2 05-22-2008 01:46 PM
Broken spark plug! HELP! supraman121 MKIII Supra 2 10-02-2006 08:40 PM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
