#11 |
are you losing fluid??
sounds like a leak if the pedal doe's not come back on its own. when my master went i could build up pressure by pumping the pedal and it was enough to stop, the O-rings inside the cylinder went bad overtime. this is like day 4 of your post its time to bleed the freakin brakes!!! thus narrowing down your search for what is wrong...
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
#12 |
Ive been bleeding the brakes for 2 days now... at first BLACK fluid was comming out with dirt in it..... (confused) kept doing it, and it started to clear up, ima do it tomorrow some more to, but the pedal is still spongy and i have to pump twice to stop. so ima keep bleeding till the fluid is clear. and then im going to replace the master cylinder
#13 |
Super Moderator
Good idea. Even if the bleeding doesn't fix it, new brake fluid is definitely better than old
1989 7MGTE R154 Targa Top White Package w/Blue Interior Driftmotion 57trim CT26, Upgraded Intercooler, 2.25" Hard Pipes, 3" Turbo Back Exhaust with Test Pipe, HKS VPC w/GM 3 bar MAP sensor, APEXi S-AFC, Walbro 255lph fuel pump, ProSport EVO Series Boost / Fuel Pressure / AFR gauges, Lotek a Pillar Gauge Pod, HKS Type 0 Turbo Timer, Eibach Lowering Springs, Tokico Illumina II TEMS struts, custom powder coated Motegi Racing TrakLite wheels |
#14 |
#16 |
Thread Tools | |
Display Modes | |
brakes dont work in cold weather | bassboy3313 | MKIII Supra | 4 | 11-21-2010 10:12 PM |
MKIII body work help | bradenman1 | MKIII Supra | 8 | 10-10-2010 02:34 PM |
MKIII Wilwood 12.9" Rear Brakes With Parking Brake | ARZ | Arizona Performance | 0 | 08-25-2010 06:34 PM |
*CLOSED* WTB - USA-Usable RHD MkIII | GTRacer | Buy/Sell Cars | 5 | 12-02-2009 02:21 AM |
13 inch Wilwood MKIII front brakes | ARZ | Arizona Performance | 0 | 03-16-2007 07:57 AM |
