Old 11-28-2010, 01:29 PM   #1
mkiiiboost
mkiiiboost is on a distinguished road
Default bubbling noise
ok so i was driving my new supra 7m gte and i was pretty hard on it and when i shut it off i open the hood and there was this bubbleing noise coming from around the turbo/cam area im not sure what it is the temp guage didnt go past half and its got a new head gasket
mkiiiboost is offline   Reply With Quote
Old 11-28-2010, 07:05 PM   #2
fantasma87
fantasma87's Avatar
i think you have air on the cooling system. get the car on a good angle "hill, jacks , what ever" and run the engine so you can release the air inside the engine and radiator hoses. make sure that its the nose that you will put facing up. hope it works. good luck
ARMY STRONG !!
Old 11-29-2010, 01:21 AM   #3
Green7mgte
Supra Forum Moderator
weres batman when you need him
Originally Posted by batmmannn
Burp the car.
I am letting it cool down now will pop the radiator and burp and fill it again.
Flush it, Burp it,
If it started after you changed your thermostat I would think you have air in your cooling system. Time to Burp it.
Check the threads on how to burp it.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Bubbling Noise Makavelli MKIII Supra 19 04-16-2011 09:37 AM
valve noise nailhead432 MKIII Supra 2 04-07-2010 03:48 PM
Wind noise near driver mirror BillW MKIII Supra 3 12-17-2009 05:09 AM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
