Old 12-13-2010, 09:48 PM   #11
Green7mgte
Supra Forum Moderator
i have a stripped exhaust bolt. i just used a concrete lag bolt lol..
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 12-13-2010, 09:51 PM   #12
907mge
907mge's Avatar
What ever works for you. Me personally, am a bit of a perfectionist and that would bother me.
Old 12-15-2010, 01:13 AM   #13
Green7mgte
it does work. maybe ill get around to doing it the right way come summer. I was holding off until i slapped on another exhaust header. but the exhaust leak was driving me crazy
Supra FAQ
Supra MKIII FAQ
Old 12-16-2010, 05:18 AM   #14
What the f#$% are you people talking about?!? I think we've got a couple conversations going on here or something.
FIRST, if the HG is blown there's no point in replacing the bolts one at a time... even if it weren't a HORRIBLE idea.... you still have to replace the damned HG and check for warpage.
SECOND, I wouldn't run a helicoil in 90% of the blocks on the market, not for the head bolt part of the equation.... there's just not enough meat in the surrounding material for me to consider it reliable after I drill the hole 3 to 4mm wider for the insert.
THIRD, Green, from what you're saying I assume you're actually talking about the manifold fastener holes (particularly the exhaust side). Two passes here is fine, on the head bolts or studs I recommend 3 or more passes at small increments but not so small that striction hits.
FOURTH, 72ft lbs for head bolts and 95 for studs... IIRC.
Old 12-19-2010, 08:40 PM   #15
Green7mgte
3 passes you say? ill write that down if i have to take my head off again.
yea i was talking about the exhaust manifold
Supra FAQ
Supra MKIII FAQ
Help on head bolt torque specs omar MKIII Supra 3 07-29-2009 11:35 AM
Need a 14mm allen head bolt for valve cover trevor217 MKIII Supra 4 10-30-2008 02:50 PM
Head bolt torque kjhsupra Non-Generation Specific Questions 3 04-06-2006 09:19 AM
ARP head bolt torque Intenseneal MKIII Supra 2 08-31-2005 10:08 PM
