Old 01-04-2011, 02:45 PM   #11
Jllahman
Jllahman is on a distinguished road
Bump! Anyone have an idea?
Jllahman is offline   Reply With Quote
Old 01-06-2011, 12:40 AM   #12
Green7mgte
Supra Forum Moderator
you have no fuel at your rail?
its either a fuel pressure problem or your entering limp mode. does your check engine light come on while this is happening?
hows your wires.. hows your spark plugs?
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=21
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 01-06-2011, 06:39 AM   #13
Jllahman
Its getting fuel to the rail, I don't know if its a fuel pressure issue though. That was my first thought.. but I don't have a gauge on the line so idk. What is limp mode?
Old 01-06-2011, 11:54 PM   #14
Sonyps307
Limp mode is when ur ecu retards ur timing and makes it run rich so you don't blow the motor mine was in limp mode just fixed it today my knock sensor wire broke had to rewire it but I was getting code 52
Really Bad weird starting problem? Raysupra MKIII Supra 7 12-04-2010 10:45 PM
Weird clutch problem wbeams MKII Supra 11 09-18-2008 05:36 AM
weird problem with my 89 performancevegas MKIII Supra 4 04-06-2008 11:38 PM
This is kind of Weird, Problem with Electric System woundsofchrist Non-Generation Specific Questions 0 11-04-2007 06:53 PM
