Old 12-06-2010, 05:52 PM   #1
jcastro
Default dose any one have the same problem
This is my second supra and the passenger window switch just gave out the little plastic piece that pushes down on the inside looks melted is there an easy permanent fix. I just put a longer spring in between but its only temp.
jcastro is offline   Reply With Quote
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
