Old 12-04-2010, 08:20 AM   #1
Mar1
Mar1 is on a distinguished road
Default 7MGE Throttle Body
Hi all, I'm from Kuwait and need an advice. I have a 1991 Toyota Crown that uses a 7MGE engine. I need a throttle body for it. the part number of the throttle body is 22210-42350
My question is, can I use any 7MGE throttle body for it? from a Cressida or Supra?
thanks
Mar1 is offline   Reply With Quote
Old 12-04-2010, 11:10 AM   #2
The upper intake of the 7M-GE from the Supra and the Cressida are quite different. Unfortunately, I no longer have access to any interchange databases to look it up for you. I'm pretty sure the Cressida throttle body will fit but I do not know if the Supra's will.
Looking at the published parts catalog the Supra's will not work... or at least Toyota says it was only used in the Supra. 22210-42310 for the A/T and 22210-42300 for the M/T.
Old 12-05-2010, 05:31 AM   #3
Mar1
Thank you for your reply, I just check toyodiy and below are my Crown Throttle body and the US Cressida one. will the Cressida one fit my Crown?
The gasket on the Cressida one looks different (#22271) while the Supra one looks nearly the same ! does this diagram help?
Crown Throttle body;
Cressida Throttle Body;
SUPRA Throttle Body;
Old 12-05-2010, 07:48 AM   #4
You can't rely on the technical drawings from a parts catalog for ush info.... BUT, seeing that it looks like the throttle body for the Crown is most similar to the Supra's TB and not the Cressida.... does the Crown have the ACIS system? Do you have a picture of your engine with the intake all installed and present?
Old 12-05-2010, 10:14 AM   #5
Mar1
This is the Crown engine bay;
Old 12-05-2010, 03:37 PM   #6
The intake system looks very similar to a Supra. In the technical drawings, it looked like a few vacuum ports were slightly different, not sure if the drawings are entirely accurate or if those differences would matter. Overall, I think it looks like a Supra TB would probably work
7gmte throttle body swap vbryanv MKIII Supra 10 05-09-2010 10:01 PM
Jdm Throttle Body Luvs2slide MKIII Supra 1 07-24-2006 07:15 AM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
throttle body boogum7 MKIII Supra 5 12-21-2005 03:01 PM
mk4 throttle body on my 7mgte?? boner1115 MKIII Supra 1 11-05-2005 12:57 AM
