Old 12-06-2010, 07:14 AM   #1
kko1516
kko1516 is on a distinguished road
Default wiring problem help?
so i bought this 88 supra last june and the day i got the altenator busted so we changed that and bought a brand new battery. Then a couple months later the battery was dead, so i got a new battery and installed brand new battery wiring. Then couple months later it died once again. Does anyone know whats going on? I think its something to do with the wiring or fuses maybe..
kko1516 is offline   Reply With Quote
Old 12-06-2010, 09:56 AM   #2
Supra_Freak_7m
Supra_Freak_7m's Avatar
Supra_Freak_7m is on a distinguished road
In rare occasions you could have a diode short in the alternator, an alternator bench test from one of your friendly parts stores should tell you if it is bad. Don't rule out the possibility just because you just replaced one. IIRC you can check for a short by:
1. Remove your - Battery Cable
2. Ground Volt meter to - battery post
3. connect other test lead to your disconnected - battery cable
4. number that reads is your short/draw*
*NOTE: Be advised there will always be a small draw for your stereo/clock/cpu memory
1987 Toyota Supra 7MGTE AUTO
1987 Toyota Supra 7MGE MANUAL
1990 Toyota Supra 7MGTE AUTO-> MANUAL
Supra_Freak_7m is offline   Reply With Quote
Old 12-12-2010, 04:07 PM   #3
MA70-3.0GT
MA70-3.0GT's Avatar
there is always the possibility that the batteries are not being "installed" properly too. When you buy a new battery & they fill it with acid, just because it can start the car straight off on it's "dry-charge" that it left the factory with, doesn't mean it's ready to use.
A freshly filled dry-charged battery should ALWAYS be put on a trickle charger and left to fully charge, ideally overnight on an automatic device. Otherwise the battery never reaches it's full power potential & can sulphate up very quickly also.
Not saying this is your problem, and I would definitely advise checking for draw as described (although this is a general test and could be alternator diodes/stuck relay/door switch/faulty alarm or anything really) and rule out any issues before replacing another battery.
Also, there are fusible links in the battery wiring that can corrode (the one that causes charging probs is marked ALT I believe) but I'm assuming you checked/replaced withthe wiring?
EDIT-:When the car is started & running, you could also put the multimeter across the battery terminals and read the voltage, this should be between 13-15v ideally if you're charging properly (do this after starting the car with a fully charged battery thats been off the charger for at least an hour & is showing around 12.7 volts disconnected) and remember overcharging (15.5v plus) can kill batteries just as well as undercharging.
Power Folding Mirror Install nfa_automotive MKIII Supra 2 05-25-2010 01:13 AM
