Old 12-09-2010, 02:58 AM   #1
xAimz
xAimz is on a distinguished road
Default Hows this block look?
xAimz is offline   Reply With Quote
Old 12-09-2010, 04:07 AM   #2
You might be a little more specific about what you're asking. A block is hard to qualify as "good" or "bad" without having it present for inspection.
At a glance I'd get it machined. The tops of the cylinder walls look chewed up, can't tell if the honing is still present and the deck surface won't do if you're looking to upgrade to a metal head gasket... plus you have no idea if it's still flat or if the cylinders are still truly round. Are the pistons all scratched or pitted or just coated in something?
Old 12-09-2010, 08:51 PM   #3
xAimz
That block has been machined
the white scuffs you see is lithium grease so it doesnt rust
i can whip it off
Old 12-09-2010, 11:17 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
What cre said is correct "A block is hard to qualify as "good" or "bad" without having it present for inspection " One thing that doesn’t look right is; why are the pistons in and oil in the head bolt holes, if the block has just been machined or have you started to re-assemble it and then decided to ask the question ?
Old 12-10-2010, 02:12 AM   #5
xAimz
the head was placed on without head gasket to prevent dust from getting inside
Old 12-12-2010, 03:55 PM   #6
MA70-3.0GT
MA70-3.0GT's Avatar
and the pistons?
Basically what Bill's asking is, when it was machined was it a BARE block with nothing else attached?
If you ask me those bores look pretty shiny & could have done with at very least a glazebust, maybe a full rebore while it was in shop. But as mentioned it is *impossible* to say if a block is good or bad from just pics (unless obvious damage makes it definitely bad), and if you're asking about the machined finish re: fitting of MHG well, we can't see for the grease anyway. Needs waaaaay cleaning up before even knowing what to do with it let alone screwing it all together.
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
decking block, reuse most parts. jvginpdx MKIII Supra 0 08-18-2009 07:03 PM
prepping block for headgasket question dannydavi MKIII Supra 1 12-06-2008 07:44 AM
