Old 12-10-2010, 01:33 AM   #1
john_lauj
john_lauj is on a distinguished road
Default starving on fuel
hi i got a 89 7mgte. i did a hg and now im starving on fuel? did i missed something or vacum holes? it starts, idles ok but when u gas, rpm goes up to 4 (max) then slowly start to drop and bogs pretty bad.. timing is good (set at 10).. anyone can help me??
john_lauj is offline   Reply With Quote
Old 12-10-2010, 02:26 AM   #2
xAimz
xAimz is on a distinguished road
7mgte is soposed to be at 12deg stock
7mge is 10
xAimz is offline   Reply With Quote
Old 12-10-2010, 05:18 AM   #3
john_lauj
yea but still that shouldnt cause the car to starve on fuel..
Old 12-10-2010, 07:05 AM   #4
7mge is 10
That's what you should see at a warm idle on each setup (roughly).... they're both still set to 10 when you're setting the timing.
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=20
Did you check for diagnostic codes? Test the AFM? Are you sure it's going lean?
Old 12-13-2010, 02:40 AM   #5
john_lauj
thats not wat im asking for.. im asking why im starving on fuel, its not timing issue.. please if ur gonna reply, reply to wat im asking about.
Old 12-13-2010, 04:57 AM   #6
I'm not jumping to conclusions.... just correcting someone and asking how the hell you're diagnosing that you're running lean.... IF YOU WANT HELP THEN ANSWER THE RELATED QUESTIONS PEOPLE ASK YOU! Otherwise stop wasting people's time and go away.
Last time I'm going to ask and then I'm just going to delete the thread: DO YOU HAVE ANY DIAGNOSTIC CODES STORED IN THE ECU AND WHAT ELSE HAVE YOU DONE TO DETERMINE THAT YOU ARE RUNNING LEAN?
Electrical problems- No Fuel thedude MKIII Supra 7 11-05-2010 12:02 PM
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
