Old 12-10-2010, 11:01 PM   #1
seth959ci
seth959ci is on a distinguished road
Default Brake caliper slide
so i decided to take a look at my front brakes today out of suspicion that one of my calipers was sticking... sure enough the front passenger side brake caliper slide is rusted to the caliper... rusted so strongly that when i rotate the caliper the slide starts to unscrew itself... any ideas? i've already tried beating on it lol
seth959ci is offline   Reply With Quote
Old 12-10-2010, 11:15 PM   #2
Beating on it is only likely to make it worse... soak it with penetrating oil... a LOT. Use the straw the oil comes with to fill it up under the boot or cut the boot off, you need to be sure to saturate the hell out of it. Heating the caliper near the glide is another possibility but I'd save that as a last resort before just cutting the whole thing off.
EDIT: After soaking the whole thing a few times and giving it a good amount of time to do it's job you can try moving the caliper on the slide toward you with a c clamp if it doesn't move the other way. Make sure its centered.
MKIII Wilwood 12.9" Rear Brakes With Parking Brake ARZ Arizona Performance 0 08-25-2010 06:34 PM
MKIV Wilwood GIANT W6A 6 piston 14.25 inch brake kit ARZ Arizona Performance 0 08-25-2010 06:00 PM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
