Old 12-16-2010, 02:01 AM   #1
DemonCandie
DemonCandie is on a distinguished road
Cool KS/Speedo Cable Problems? Plz Help
Hey guys, just bought an 87 N/A Supra. Basically its throwing a code 52, the speedo doesn't work, The overdrive light flashes over 40, and the car has literally no power hardly at all. Even if you floor it. I've done quite a bit of research on this website and it seems everyones pretty knowledgable. The trans goes into every gear smoothly. Just has no power, its not plugs or a fuel problem or anything little like that. Also I notice some wiring down there by the KS that didn't look too professional. Also I'm in Bloomington, IN with a foot of snow so I really don't wanna take the starter off Got any tips anyone?
DemonCandie is offline   Reply With Quote
Old 12-16-2010, 03:30 AM   #2
907mge
907mge's Avatar
The o/d off light flashing is a warning and code indicator for the transmission. Here is the Toyota repair manual for a 1990 but should point you in the right direction.
http://www.cygnusx1.net/Supra/Librar....aspx?S=AT&P=1
Old 12-16-2010, 03:37 AM   #3
DemonCandie
Wouldn't the tps throw a code? When its in park or neutral the engine feels like it has full power. It shifts through all gears fine. Just accelerates at maybe 25% percent of what it could
Old 12-16-2010, 04:25 AM   #4
52 is a critical code and if the ECU is actively seeing the fault the ECU will go in to what is commonly known as "limp mode".... the ECU dumps in tons of extra fuel and pulls very large amounts of spark advance very effectively neutering your engine of any balls it once had.
The transmission problem is very likely due to the inoperable speedometer. The speedometer is where the speed signal for the transmission is generated.
Fixing the speedometer and the knock sensor and/or its wiring may be the sum of what's needed to restore power and driveability.
Old 12-16-2010, 04:28 AM   #5
907mge
907mge's Avatar
See if you can pull the code for it. It gives instructions in the link on how to do it. All you should need is a small piece of wire or paper clip.
Old 12-16-2010, 05:35 AM   #6
DemonCandie
You guys are reassuring! Is the next sensor common to go out or is the wiring most likely? Its an Indiana car and I'm sure its had the piss ran outta it. The elements aren't exactly forgiving up here.
Old 12-16-2010, 05:45 AM   #7
DemonCandie
Oh, and btw I pulled the code it was a 52 ^^above. I'm pretty sure the flashing is just because of the speedo sensor. I'm on a pretty low budget so I'm lookin to fix the one thats making the car fall on its face first.
Tags
7mge ks wiring lost?
Speedometer Cable Help corey1517 MKIII Supra 1 02-13-2010 06:56 PM
Speedo cable problems... Raysupra MKIII Supra 7 11-01-2009 03:47 AM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
Extra Cable? 808Supra MKIII Supra 1 08-17-2006 08:15 AM
I need help on the computer and your info on the throttle cable! 89n/aA/T-2turbo5spd MKIII Supra 2 05-07-2006 05:25 AM
