So if I take my 7mgte supra that has the following mods..
3'' cat back AEM intake So if I was to say~.. What if I did the Lexus AFM Upgrade???? Would that be ok or will I be throwing the whole system into shams? I just need the Lexus AFM to do the mod right? Is it a direct swap? |
Direct drop in yes...
Without fuel pump and 550cc injectors you will run lean. It basically allows more unmetered air into your engine.
1990 Toyota Supra Turbo A/T ------------------------------------------------ Questions about oil? take a look http://www.supramania.com/aehaas/ |
^ agreed. you could bypass the 550cc and get an safc but you would need a AFR gauge to see how much to increase or decrease
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
You don't need an upgraded pump for this mod, the stock one flows more than enough. You DO need to be 100% sure yours is in good shape (so might as well replace it with a better one anyway). As mkiiisupra said, you must install the injectors first or prior to the AFM or you will run lean at WOT.
What is the Ultimate Economical 7GTE-M Upgrade??? | Bruno Molly | MKIII Supra | 0 | 05-10-2009 04:30 PM |
Lexus 550 injectors and afm upgrade help plz | flnbobpogoman | MKIII Supra | 3 | 08-05-2006 08:51 PM |
Lexus AFM question? | rnoswal | MKIII Supra | 13 | 04-20-2006 06:34 AM |
