Old 12-21-2010, 09:49 AM   #1
87hilux7mge
87hilux7mge's Avatar
Default 7mge build with some questions.
hey everyone, new here, looking for some info/input. now, first off, no i dont own a supra anymore. used to have an 89 turbo in high school, but have since gone thru several other cars. currently i have an 87 toyota 4x4 pickup, that is what the 7mge im building is going in. these arent swap specific questions, just motor questions.
first off, ill give you a parts list so you know what im working with.
bored/honed/decked jdm block- .50mm (.020) over
PnP/milled jdm head
comp valve springs
BC 268 cams (stage 2)
adj. cam gears
NPR pistons, rings (.020) over, balanced
eagle H beam rods, balanced
polished crank, balanced
king main/rod bearings
header (hey, was free )
ATI damper
about 9.4-9.5 compression
stage 2 6 puck clutch kit
will have rebuilt w56 with 4.10's running 32" tires with a locked rear.
now i know not everyone is a fan of the GE, but please dont flame me saying i should get a turbo. ive done a crap load of research already and used the search function here and gotten some good info. the reason i dont have a turbo, is because i picked up this entire drive train originally for 100 bux (motor, tranny, harness, ecu and various other parts) not to mention a complete spare motor out of a 90 cressida, with harness, for 85 dollars.
i want to get into an EMS but i cannot find one for the GE, ive checked megasquirt and AEM and they both only offer for the GTE as ive seen.
heres where im gonna get ripped.. i have a custom supercharger setup (that i built, yes i can hear you all laughing) for my old 91 firbird formula w/ a 305. this kit can be adjusted with my pulleys to put out 5, 8 or 10 psi. i plan on putting this on the GE down the road running 5 psi to start, mounted where the AC was and running it thru an intercooler.
my question is, should i (can i rather) convert this all too GTE electronics, get the AEM ems and run it N/A till i finish fabbing the supercharger brackets, then tune it to run with the supercharger? AEM has told me they dont make an EMS for the GE, megasquirt wont pickup, email back etc.
the only other option i can think of is getting an apexi NEO, but i dont think that will allow enough tuning, especially with the cams and all. i wont be tuning for peak hp (not my style) as im an "under the curve/average hp" kinda guy. ive built quite a few engines, mostly carbed, but this is the first time ive considered an aftermarket ems, and the more advanced import build ive done.
i have about 3k into the motor so far, and can go about another 2-2.5k, but hope i wont have to do that much. if i can get the AEM ems to work with the GE electronics or even convert to GTE, i know where i can get the AEM for 500 bux. if not i can get the neo for 150 and hope for the best.
neway, hit me up with any kind of info you got, i appreciate it. and please, dont just flame me saying "go turbo!" ive decided to do the supercharger, cuz its unique and i like the power curve it gives me.
thanks!
Old 12-21-2010, 01:57 PM   #2
all that is pretty useless for a 7mge. 7mgte is the way to go. turbo baby
Old 12-21-2010, 03:12 PM   #3
Way to go, Green.
I'm not 100% sure on this, but you should be able to run the AEM with the GE if you run all GTE electronics on the engine.
Old 12-21-2010, 03:38 PM   #4
lol oops.
walks away in shame..
well in my defense it wasnt a flame. I just read the first part thinking its some kid who dosnt know crap and yadda yadda you know the rest.
but actually reading the post. pretty intelligent.. my fault.
Old 12-21-2010, 04:22 PM   #5
I don't know about the AEM, but if that doesn't pan out I'd look into the MAFT Pro.
Old 12-21-2010, 09:32 PM   #6
87hilux7mge
green, apology accepted. not a "kid" but not an old man either. been into engines for about 10 years, just always stuck with a "tune by screw driver" carb setup, except for the turbo 93 altima i had (jim wolf ecu retune).
anyway, i havent checked maftpro yet, ill look into that, im gonna call AEM again today as well as APEXi, see if they say anything promising about swapping to gte electronics. everyone said that the turbo electronics wont run in N/A form. i dont see why, its would just run out of boost for the time being, and in my mind, probably be more efficient due to the multi coil design, full electronic timing control, etc. combine that with the AEM tuning capability (or maftpro) and i think i may be able to at least get it running decent, till the S/C goes on.
i have to get the motor in the bay and see how i can mount the S/C, its a lil tight but i think ill have enough room in the ac position, if i make the custom brackets and remove the stock one. im going to try to retain the stock bracket, but may come to down to a bust.
neway, ill be able to use the extra block to fit it all too once i can get some measurements.
so im guessing the consensus is: SAFC Neo is out (not enough capability), AEM is possible if i can swap to gte electronics, and maftpro is worth looking at/talking to someone about.
any other comments? sorry if i had a digi cam id take some pics and my damn celly camera broke 2 months ago (run over in parking lot)
once again, thanks for any comments, aside from "go turbo" ones, haha.
Old 12-21-2010, 10:17 PM   #7
My friend with a 84 Toy pickup has a 7MGTE in it, and you're right; it's a tight fit.
You can run a GE on GTE electronics. GTE uses higher flow injectors, and the computer is obviously expecting to see boost at some point, so fuel curves might be off. But since you're thinking of running a standalone AEM, you should be able to tune out the differences for now and adjust accordingly once you get the S/C on it. So I don't think you'd have a problem (this is purely speculation on my part, but it makes sense to me)
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
couple of questions about my 7MGE motor SDK MKIII Supra 2 12-13-2009 07:26 AM
questions? for a 92 7mge btharper MKIII Supra 0 11-03-2006 02:58 AM
