Old 12-23-2010, 12:05 AM   #1
Sonyps307
Default 7mge tps
Can a bad or if the tps in out of calibration mess up the timing
Old 12-23-2010, 12:41 AM   #2
Sonyps307
I also get code 51
Old 12-23-2010, 02:17 AM   #3
Code 51 (when caused by the TPS) is specific to the IDL switch inside the unit. This switch tells the ECU when the throttle is closed so it knows better how to operate the IAC (Idle Air Control) valve. If the IDL switch is not closing when the throttle is the ECU will just pump the IAC to keep the engine running.... so your idle will be inconsistent. You cannot set timing in this situation... you must have no codes (not entirely true, but a good practice), the engine must be up to normal operating temp and the diagnostic jumper must be in place. Do know that a code 51 will also present if you press the gas while in diag mode or turn on the A/C.
What's wrong with the timing?
Old 12-23-2010, 03:39 AM   #4
Sonyps307
Well the car is low on power so I timed it. it was reading Belong 0 so I retimed it to 10 with the jumper took it around the block and it ran better intill the engine light came on then I checked codes again got 51 and 52. So then I timed it again now it's moving on the 15 and alittle above 15. The motor was just rebuild and I also had them glass beed the throttle body and intake so I sure they took off the tps during this and now it's off mess up I think
Old 12-23-2010, 04:35 AM   #5
You see people.... it would be MUCH easier if you'd include the whole story from the beginning.
A code 51 isn't going to cause any significant power loss.... Your code 52 on the other hand is a biggie.
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
7mgte to 7mge conversion help wayzhack MKIII Supra 7 09-07-2010 08:22 PM
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
7mge vs. 7mgte KNYFE MKIII Supra 3 09-27-2005 02:21 PM
