This is my 1986.5 Supra that I bought about a year ago on craigslist for $750. Since then I've replaced the clutch, oil pump, put some tokico illumina 2's on there, new wheels, radiator, and plenty of odds and ends. I bought it with a remanufactured head and some other minor work, but due to the head bolts not getting re-torqued, the head gasket went a couple months ago. So I did my first engine pull in my auto tech class and rebuilt the bottom end, resealed it all the way, and made it look pretty. Everything was stock size still, so i replaced rings and bearings and gaskets and kept the pistons. I scratched the head surface at one point and had to take the cams off to get it milled. Luckily this happened, because i noticed a groove in the intake cam on the last oil hole. it would have eventually broken and blew my engine up. lol. I got the new (old) one from my parts car.
Also special thanks to bioskyline, who sent me a piston for only shipping cost after one of mine fell off the table. Being a high school student, i couldn't afford much more on this build at the time and he helped the build finish! thank you Here's some pics. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I decided to switch it up a little and put SUPRA on the timing belt cover and put the 7MGE on the intake. Let me know what you think! I apologize if the pics are a little blurry, they were taken with my phone. Last edited by Cameroonski; 12-25-2010 at 01:23 AM. |
BAD ASS DUDE, keep the good work, post more pic of the project.
Nice 87 Supra, Pearl white, targa top, 5 spd, 7mgte ![]() ARMY STRONG !! La fiebre Boricua Puerto Rico!!! ![]() |
nice clean engine.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
So guess what? Three gas tanks and i have a blown head gasket. I had everything how i wanted it and then, white smoke and low coolant. fml...
anywaysss... what is everyone using on their head bolt torque? Ive got ARP bolts, and torqued them to 95 ft/lbs. I did it in the correct sequence, and then re-torqued them at 500 miles before my break in oil change. i dont understand why it went, i drive it hard, but come on! ![]() I was about to sell my jeep, and put more money into this. now im not sure what i should sell and thinking that i should get a bike... but i REALLY REALLY dont want to sell my supra! so any advice to make sure i dont get a BHG again? other than keep the rpm's under 3k? lol Thanks! |
What hg did you use? Brand?
Was the head flat as it should be? I did mine a few thousand miles ago. I did: arp head studs 90ft/lbs permatex copper spray felpro hg retorque after a few heat cycles |
#6 | |
![]() Quote:
thats what i did. except the copper spray, how does that work? i guess ill just replace it and hope it doesnt happen again. |
#7 |
I don't know about the JIS gasket kit. Aren't they sold on ebay? I wouldn't worry except for the hg, I wouldn't skimp there. The felpro kit is like $220 on rockauto.com and from what I saw when I put it in, it is of quality equal to oem. The spray is sold at almost every parts store and should be applied to both sides of the gasket before install.
#8 |
i hope not.. lol. i forgot which website i got it on but i didnt get it from ebay.
ill go for a high quality felpro or something hg. get some of that spray. and hope i dont scratch up all my pretty paint in the process. lol. and torque it to 95 again. Thanks for your help! |
7MGTE Build up suggestions 350hp - 400hp | Supra Saiyan | MKIII Supra | 18 | 08-07-2010 03:12 AM |
Cannot build up boost :( | azerty | MKIII Supra | 4 | 04-22-2009 03:56 AM |
3.4 bored out stroked supra build | Fredy171787 | MKIII Supra | 2 | 04-12-2008 03:10 PM |
Mad Carbon Build Up | supraman121 | MKIII Supra | 2 | 04-24-2007 04:22 PM |
Engine build... | h8z2luze | MKIII Supra | 5 | 12-08-2006 03:55 AM |
