Old 12-26-2010, 10:55 AM   #1
MrMK3-707
MrMK3-707's Avatar
MrMK3-707 is on a distinguished road
Question Missing Plugs
Can somone tell me what these plugs go to. I just replaced the Headgasket and plugge up everything i could and all that was left was these. The one on the exhaust side wasnt plugged in at all
ID:	3602   Click image for larger version
ID:	3603   Click image for larger version
MrMK3-707 is offline   Reply With Quote
Old 12-26-2010, 02:54 PM   #2
907mge
907mge's Avatar
I think what they are is the plugs for the actuators for the adjustable suspension that you don't have. I also have the same loose plugs. I'm guessing that toyota did not want to make too many different wiring harnesses so they made them all with these plugs.
Old 12-26-2010, 06:19 PM   #3
The first and second pics look like the harness connection for the automatic transmission... M/T guys just get used to ignoring them, but that's the only 4 pin connector in that area that I can think of. Check the wire colors in the TEWD to verify.
The third pic does look like a connector for the TEMS option, but for not having been plugged in for 20 years, wow it does look clean... There should be a matching one on or near each strut tower.
Old 12-27-2010, 06:33 AM   #4
MrMK3-707
MrMK3-707's Avatar
Talking
Thanks for the help. Just didnt want to leave anything unplugged that would stop the car for starting. Turns out that the ignition coil went bad because there was no spark comming from it when i turned the key.
Lets hope the new one gets it to start
Old 12-29-2010, 05:22 PM   #5
MA70-3.0GT
MA70-3.0GT's Avatar
Just a thought, did you reconnect the earth wire to the coil pack? Not sure if it's the same on N/A but on the turbo the coil pack has a seperate earth wire that needs to be hooked up (it was snapped on mine!)
Old 12-29-2010, 08:51 PM   #6
MrMK3-707
MrMK3-707's Avatar
The coil only has one plug comming from it and its plugged up. And it has a solid ground too. So im still lost on why its not sparking
Old 12-31-2010, 07:49 PM   #7
MA70-3.0GT
MA70-3.0GT's Avatar
Could be a faulty igniter (the GE motor also uses this system) or a fault within the distributor/rotor arm...
Hopefully this link will help with what to look at & where Mr. T has it hidden http://www.cygnusx1.net/Supra/Librar....aspx?S=IG&P=1 hth
EDIT-: More specifically, this checklist should get you sorted http://www.cygnusx1.net/Supra/Librar...Section=IG&P=5 Follow that baby & you'll find the problem in next to no time
Old 01-01-2011, 02:33 AM   #8
MrMK3-707
MrMK3-707's Avatar
Cant be the igniter either cuz i tested it on my friends MK3 and it works fine. Im gonna replace the distributor and see what happens next
Tags
harness, plugs, wiering
Help...My spark plugs are in the oil !!! chinesedawn MKIII Supra 6 10-03-2011 09:25 PM
Coolant plugs? scaggsj MKIII Supra 14 04-13-2010 12:00 AM
Spark Plugs and Water cgreiner MKIII Supra 1 07-21-2009 03:49 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
