Old 12-27-2010, 06:24 PM   #1
Burn N' Up
Burn N' Up's Avatar
Default I need to know the inner diameter of the 89-92 Turbos rear A arm bushing holes
The title pretty much said it. I'm going full poly on the rear A arms and trailing arm so i need to know the inner diameter on the bushing hole so i can get the right size bushings. Any help me out? Inches or metric, doesn't matter your measurement. THANKS!
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
Old 12-27-2010, 10:42 PM   #2
907mge
907mge's Avatar
Why not just buy the set?
http://store.driftmotion.com/static/i-83127g.php
