Old 12-28-2010, 06:13 AM   #1
MrMK3-707
MrMK3-707's Avatar
MrMK3-707 is on a distinguished road
Question No ignition coil spark. Plz help!!
Hey everyone, Just finished my head gasket problem. Tried to start the car at first and didnt have enough power. Ended up getting a new battery and it turns over fine but it doesnt start. Went and checked the ignition coil and there was no spark.
I took it to my friends house and hooked it up to his car, which is the same exact car as mine and his is 100% stock and restored, It worked fine on his car. I even used my coil wire on his car and it still worked fine. Can someone let me know what im doing wrong???
p.s. The car stopped running before i took it appart to do the head gasket.
MrMK3-707 is offline   Reply With Quote
Old 12-28-2010, 06:53 AM   #2
Look through the TSRM to diagnose no spark situations. It's possible that your igniter has gone bad. That's just one of many items that can stop the system from sparking though
Old 12-28-2010, 11:12 AM   #3
MrMK3-707
MrMK3-707's Avatar
Is the igniter in the same place as the coil?
Old 12-28-2010, 05:11 PM   #4
Well, it depends on the engine. Now that I re-read your post, it seems that you have a 7MGE engine since you swapped out the coil instead of coil packs... I know that the GTE uses an igniter on the fender, but I can't remember how the GE is set up (don't currently have one). Maybe someone can pop on here and give a little more information.
Have you been reading through the TSRM to troubleshoot this?
Old 12-29-2010, 01:39 AM   #5
MrMK3-707
MrMK3-707's Avatar
All ive been seeing is something about using a jumper wire in the fuze box under the hood. Can you tell me anything about that
Thanks.
Old 12-29-2010, 01:45 AM   #6
MrMK3-707
MrMK3-707's Avatar
Post
And yes it is a 7MGE (automatic)
Heres a recent pic of mine. If it helps any
Old 12-29-2010, 09:20 PM   #7
Well, I would follow this link to the TSRM. This one's on the ignition system, so just follow the troubleshooting guide.
Tags
coil, ignition
Ignition Coil gorillaguy8 MKIII Supra 3 03-29-2010 12:54 AM
Ignition coil question RawrXTC MKIII Supra 6 02-20-2009 03:12 AM
No Spark From Coil SilenceboneSupra MKIII Supra 10 10-17-2007 03:10 PM
Ignition Coil or Igniter? scruffboy Non-Generation Specific Questions 2 02-13-2007 02:13 PM
