Old 01-01-2011, 10:46 AM   #1
Preston
Preston is on a distinguished road
Default power steering problems.....any help?
so i just payed 425$ for a new power steering pump for my car because i would prefer to have the power steering fixed.
it still is leaking but while the fluid is in the car for the little time it is, the cars steering is excellent.
so i know i have a leak... is there any possible way to find out? any tricks?
what do you think the problem could be?
Preston is offline   Reply With Quote
Old 01-01-2011, 03:19 PM   #2
Could be a powersteering hose, leaking seal in the rack, cracked reservoir... You can clean it all up, put some UV die in the system (the one that works with transmission fluid), and top it off with Dexron II ATF (or equivalent). Once you run it, throw on your UV glasses and check everywhere with the light. You should be able to find the trail from where it's leaking from
Old 01-02-2011, 12:24 AM   #3
what about using a rad pressure tester?
they have a shit ton of adapters.
or would that screw something up?
Old 01-14-2011, 01:34 AM   #4
Preston
Default return hose
it was the return hose or something like that... not a big fix but i knew it had to b a hose or something because the pump was working it just couldnt keep the fluid in. so its fixed and not leaking at all anymore
No power steering 90supra MKIII Supra 1 11-01-2010 01:17 PM
Power Steering cables wet (leak) question rjSupra MKIII Supra 2 09-20-2010 11:34 PM
problems with my power steering pump pulley... maniakwithpistol MKIII Supra 1 12-05-2008 09:16 PM
Steering problems drmmr15 MKIII Supra 17 03-08-2007 09:32 PM
Power steering fault david small Non-Generation Specific Questions 1 09-20-2006 12:41 AM
