Old 01-04-2011, 08:32 AM   #1
MrMK3-707
MrMK3-707's Avatar
MrMK3-707 is on a distinguished road
Talking update!
Just found that there was alot of water in the exhaust. Catalyc conv and muffler. Ran it for about ten min with alot of high rpm revs and its all cleared out.
MrMK3-707 is offline   Reply With Quote
Old 01-04-2011, 09:25 AM   #2
Sonyps307
If you was burning oil it would be bluish smoke did u torque the head bolts to the right spec or the head might be warped and needs to be shaved has the car ever overheated before
Old 01-04-2011, 11:38 AM   #3
MrMK3-707
MrMK3-707's Avatar
Yea the bolts are torqued right and it doesnt over heat at all. The only thing was the water in the pipes. It doesnt smoke anymore. Now it just needa to be fine timed.
Old 01-04-2011, 06:24 PM   #4
MrMK3-707
MrMK3-707's Avatar
Unhappy White smoke. Someone help!!!
Ok i just replaced the head gasket on my 7MGE. Got it all back together and then it ended up not starting. It stopped starting before i changed the head gasket. So i tried a bunch of things and i still couldnt get it to sart. I Ended up taking it in to the shop and had them check it and they said the mass air flow sensor had an internal short in it and wasnt producing the 5 volts to let the car start. So i went out to pick n pull and got some parts for it (including the sensor) and the car started right up.
Now while the car is running all i get is white smoke. I dont know what i did wrong so can someone give me some ideas.
Also, would adding too much oil have anything to do with it?
Thanks,
Old 01-06-2011, 12:45 AM   #5
Thanks,
lawl. i was reading your post then came across the last line. gave me a good chuckle.
if it was more than a quart over then yea i would say you blew some seals there bucko
Tags
blown, gasket, head, smoke, white
white smoke while below 1500rpm and over heating spunkenhimer MKIII Supra 22 02-12-2011 06:04 AM
white and blue smoke after rebuilding head block ahruizguerra MKIII Supra 2 10-01-2010 07:50 PM
White smoke from exhaust manifold Rommy MKIII Supra 15 07-26-2009 06:32 PM
help! white smoke out tail pipe tone loc MKIII Supra 5 08-04-2006 10:29 PM
White Smoke Drag0na5h MKIII Supra 1 04-25-2006 06:36 AM
