#1 |
Last Summer I bought and 88 supra 7MGTE targa from my neighbor. It has 19xk miles on it. He stopped driving it when a collant hose blew out. He parked it in his garage for a couple of years. He sold it to me for $400
![]() [He said that it has been taked care of really well, 3 preventative Timing belt changes, always kept up on the fluids. ect.] I fixed the hose, changed the fluids and took it in to check the head gasket and, looks like the head gasket is leaking. The hydrocarbon count was about 100 ppm in the coolant. So I am planning on replacing the head gasket in February. After driving it a couple times, I'm pretty sure that the turbocharger is out. I'm only getting about 4lbs of boost at best and it makes a sound when it is about 0lbs of boost. At first i thought it was a leak in the intercooler hosing, but now I doubt that is the case. Long term I would like to have a complete engine rebuild done on the lower end, have the block machined and what not. Right now I am thinking, for the short term, to just rebuild the stock ct26 turbocharger. I'm looking for a place that rebuilds turbos and was wonder if i could get any answers form here. (price?) I would also like to discuss my options with my supra. ![]() And, I took it to a shop for an estimant and asked them about the torque on the head bolts, they said that their procedures on the torque specifications were to tighten it to 59 ftlbs of torque. I've heard that it should be much higher that that. I've heard that it should be torqued to 75 ftlbs of torque. Is that correct? |
#2 |
Do not retorque factory head bolts, they stretch and it will not do you any good.
Get ARP studs and torque them to the directions that come in the box, its like 90ft/lbs or so. Turbo rebuild www.driftmotion.com
1990 Toyota Supra Turbo A/T ------------------------------------------------ Questions about oil? take a look http://www.supramania.com/aehaas/ |
#3 |
Supra Forum Moderator
thats all well and good. but you dont have to get studs. bolts work just as well and are a little cheaper in price, not quality. but if you wanna spend the extra $13 bucks have at it, its a good idea but not mandatory, as long as your holes are in good condition.
as far as a rebuild goes, your best bet is to find a local relabile shop. not a custom tuner shop that the kids go to but a real machine shop that specializes in turbo's. like a semi truck facility. should only run you around 250 if its in decent shape. if not your better off buying a new one or "refurbished" from a reliable dealer. that will cost you around 5. usually your local shops will take it in and have a look to see if its rebuild able or not.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#4 |
That all sound good. I think that I am going to go with the studs. The funny thing is, I asked one of the mechanics I was going to go to, specifically, if I should replace the head bolts, and he said that it was not necessary.
Is there any consequence for over torquing the head bolts? 90lbs seem like a lot, compared to what I have heard. |
#5 |
as i said before, its not if your bolts, threads. holes are all in good shape. bolts are set to 75 lbs torque and studs are what.. 85 90? idk have to look it up on here.
what you do is torque them.. drive acouple.. re torque. no don't over torque the first time.
#6 |
Alright. How difficult is it to get to the head bolts? If I'm not mistaking you have to take apart the value cover and what not. I'm planning oh having my head gasket done in a shop. I've never worked on an engine this big, just little 4 bangers. Do you think I should have them torque them to a certain point and the re torque them myself?
88 Supra Tegra 7M-GTE Manual ![]() Seattle, Washington (Granite Falls) |
Toyota Supra 1992 Rebuild engine? | ngmc11 | Non-Generation Specific Questions | 3 | 08-25-2009 07:47 PM |
Supra Rear End Rebuild! | OsiowyMK3 | MKIII Supra | 3 | 08-17-2009 05:31 PM |
having a problem: my first supra rebuild | lunar0utlaw | MKIII Supra | 1 | 07-10-2008 02:21 AM |
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
1988 supra engine rebuild | 1988Suprakid | MKIII Supra | 5 | 06-07-2006 09:07 PM |
