Old 01-10-2011, 11:10 PM   #1
johnvin
johnvin is on a distinguished road
Default rebuild kits need your help!
hey sup guys im looking to rebuild my motor in my 1988 7mgte twin cam, the kit that i found is like $425 for the non turbo and mine is non turbo but im not sure if it would be any diffrent if i would get the turbo one it comes with
This kit contains complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable), and a set of expansion plugs (does not contain camshaft, timing kit or oil pump). Pistons & Rings: Std., .020, .040. Bearings: Std., 10, 20, 30
im not sure if it would be any better or if i would even be able to do it . because if i go with the turbo one its cheeper . the web site is
http://www.rpmmachine.com/shop/index...t_detail&p=215 thanks guys !
johnvin is offline   Reply With Quote
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
7mgte rebuild questions bradenman1 MKIII Supra 0 05-27-2010 03:36 PM
Replace or Rebuild a 7mge cbrewster MKIII Supra 2 03-19-2009 10:20 PM
