hey sup guys im looking to rebuild my motor in my 1988 7mgte twin cam, the kit that i found is like $425 for the non turbo and mine is non turbo but im not sure if it would be any diffrent if i would get the turbo one it comes with
This kit contains complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable), and a set of expansion plugs (does not contain camshaft, timing kit or oil pump). Pistons & Rings: Std., .020, .040. Bearings: Std., 10, 20, 30 im not sure if it would be any better or if i would even be able to do it . because if i go with the turbo one its cheeper . the web site is http://www.rpmmachine.com/shop/index...t_detail&p=215 thanks guys ! |
The 7mgte is a turbo motor or do you have a 7mge? And the pistons will be different.
![]() i have the 7mge motor. the non turbo , i put it on there wrong. so your saying that the kit wouldnt work for my non turbo ? i would have to go with the more expensive kit? what parts could i use for my non turbo motor from the turbo model ?
id check on ebay man.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
Rockauto.com has kits or magauto is good for oem. But the kit you are looking at looks more brand x. I would at least buy a nice headgasket and arp headbolts. And are you redoing the head also?
#6 |
The turbo kit would work but the pistons r lower compression which means on a non turbo motor less power
#7 |
Sometimes you'll find kits cheaper if you search for "Cressida" instead of Supra... There are a couple different gaskets on the intake but that's all, EVERYTHING else is the same.
I've had good luck order OEM type parts from an eBay vendor named Mizumo Auto Parts. I don't see any full kits in their listings right now but you could contact them to see what kind of deal they'd make you. If you were to buy parts from their current listings you should be able to piece a full kit together for about the same price. http://cgi.ebay.com/Toyota-3-0L-DOHC...item3cb2a23c8c http://cgi.ebay.com/89-92-3-0-L-Toyo...item53de461fbc http://cgi.ebay.com/Toyota-Supra-Tur...item3cb29be5a0
#8 |
im looking to rebuild the whole top end as in the rods berings pistons rings and new head gasket and i plan on going with the apr head bolts i heard a lot of good revews on them . this will be my first car and my first supra i just want something fast and something i can smoke all my freinds cars in lol thanks guys!
#9 |
Well here goes another supra to the junk yard. Is it an auto?
#10 |
what would be a good web site to get some good rods for it? i think im just better off rebuilding the top end not quite sure yet, the motor is just about ready to be pulled , when i got the car it hasent been ran for awhile i only payed 400 for it and the guy who i had bought it from put a new cluch and new head gasket on it and he drove it for like 100 pluse miles and it started knocking really bad so when i got it i put a new battery in it and started the beast up and like he said it had a really really bad knocking to it and i reved it up and it goes away just a tad bit but its still really bad thats why i think i should just rebuild it and also it has 272,000 miles on it ... what do you guys think i should do ?? THANKS SOOOO MUCH
1986 Turbo Automatic Transmission Rebuild? | professorbob | MKIII Supra | 2 | 01-26-2012 01:06 AM |
7mgte rebuild questions | bradenman1 | MKIII Supra | 0 | 05-27-2010 03:36 PM |
Replace or Rebuild a 7mge | cbrewster | MKIII Supra | 2 | 03-19-2009 10:20 PM |
