Old 07-15-2011, 05:49 PM   #11
Green7mgte
Supra Forum Moderator
check your wires.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 07-15-2011, 10:07 PM   #12
keegan
keegan is on a distinguished road
I did and I could not find anything but know its poping a lot of codes like 24 31 41 51 I know what the two are and 24 and 31 I don't
keegan is offline   Reply With Quote
Old 07-16-2011, 02:55 AM   #13
MK3Newb
MK3Newb is on a distinguished road
You say its not running... what exactly do you mean . Will it start then the throttle wont idle properly? does it not want to stay idling at all... could be the maf/map or if it idles high then dies could be the Idle air control valve. Pray its not the IACV cause thats just 400 bucks for the part not to mention new seals and the pain to switch it out
MK3Newb is offline   Reply With Quote
Old 07-16-2011, 03:14 AM   #14
keegan
The car will turn on and idle some what but when I give it gas its like there is no response for a litttle but then it will jump up and stay around 3 grand with foot on floor but when I let off it will still idle the same
Old 07-19-2011, 03:09 AM   #15
Conga1991
Conga1991 is on a distinguished road
Thats what happened to me. Had a supra enthusiast come out and look at it, my cps was off a tooth and my tps was bad, so it was thinking it was wot so it was dumping fuel and fouled the spark plugs. check those just in case they are fouled or not.
Conga1991 is offline   Reply With Quote
Old 07-19-2011, 01:18 PM   #16
keegan
Thank you for the help ill check the cps and everything else
Old 07-26-2011, 05:18 AM   #17
Mk3FirstCar-Mike
Mk3FirstCar-Mike is on a distinguished road
Could be a number of things:Starter, Engine is running lean, corroded battery/other electrical wiring - When you do get it running, I recommend High Mileage GumOut. It works wonders and it's only like $5 at Walmart.
Mk3FirstCar-Mike is offline   Reply With Quote
Old 07-28-2011, 04:25 PM   #18
keegan
I got the car to run but now when I check the codes the light flashs rapidly with no stop have you guys ever heared of this problem
Old 07-28-2011, 04:53 PM   #19
Conga1991
Im pretty sure that means you have no problems, but check the tsrm just incase it does... just checked and it means there are no errors in your system. Is it running weird??
Old 07-28-2011, 11:50 PM   #20
keegan
Yea it starts but. When I give iit gas it lags and dos not want to go I thought it was spark but now I'm leaning more towered fule
Supra bumper turn signal bulbs (for TRD bumper in non-Supra) Coldair MKIV Supra 8 03-15-2009 04:44 PM
Got the supra to turn over today... OkieRA29 MKIII Supra 8 10-06-2008 02:28 PM
