Old 01-18-2011, 04:29 AM   #1
mauimale5799
mauimale5799 is on a distinguished road
Default How to replace a head gasket
Can anyone that has replaced the head gasket give me some pointers and also the "new" torque specs to reduce the chances of it blowing again.
Also, whats the cost to complete the repair.
mauimale5799 is offline   Reply With Quote
Old 01-18-2011, 04:45 AM   #2
907mge
907mge's Avatar
Read through the MK3 FAQ section at the top of the MK3 section and this should help:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
I would get arp head bolts at the min and I believe the spec is 75ft lbs
Old 01-19-2011, 04:52 AM   #3
89ST
89ST is on a distinguished road
If you don't find some details you're looking for there. I can hopefully help you with any extra questions.
89ST is offline   Reply With Quote
Old 01-20-2011, 03:46 AM   #4
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
A common mistake I have watched two people make is make sure when it's all put back together and head studs are torqued to spec (I did at 75 pounds)
make sure you set the timing by turning the crank pulley so that the #1 cylinder is at TDC (top dead center) on the compression stroke
and then set the correct timing on your cam gears.......Also after everything is finished before you run the wires to your spark plugs crank your engine over for a couple minutes so you pump the oil and coolent through out your engine and turbo
supraturbo_mk3 is offline   Reply With Quote
Does the exhaust manifold need to come off to replace head gasket? BillW MKIII Supra 1 10-02-2009 12:19 AM
Head Gasket Gone. Gonna Replace The Motor, But What Kind? superman.dustin MKIII Supra 5 05-16-2009 11:21 PM
hks head gasket suprabahamut MKIII Supra 8 09-01-2007 04:28 AM
