mk3 supra hood emblem??
how do u remove and replace the TOYOTA SUPRA emblem on the hood?
You have to remove the nose piece altogether and then disassemble it. They're not the easiest little bastards to get to. There are two nuts inside the fenders all the way front which need to be removed, then two on the support which bolts to the sheet metal by the wall between the grill cavity and the head lights and one which connects to the latch support. Pull the turn signals and look close and you should be able to find the rest.
