Old 02-18-2011, 08:53 PM   #1
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
Default Brake Light Nightmare
The lamp failure box has already been bypassed by the previous owner. All the lights work on the car except the stop lights. The taillights, turn signals, hazards, reverse lights, and the license plate lights also work. What to do?? Any suggestions will be appreciated. Thanks.
P.S. I might also need a copy of the wiring diagram, because every single one I get doesn't seem to help.
supraheelfan is offline   Reply With Quote
Old 02-18-2011, 09:03 PM   #2
Posted in the wrong forum... moved to the MKIII forum... I assume this is a MKIII.
Double check the previous owners work and test the brake switch. The brakes are on their own circuit and it is a VERY simple circuit.
Here's Toyota's wiring diagram:
http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=074
Old 02-19-2011, 08:22 PM   #3
supraheelfan
Thanks for the diagram it really helped. Yea sorry for posting in the wrong spot, kinda new so... I have more questions also.
Old 02-19-2011, 08:49 PM   #4
supraheelfan
Default Eibach Lowering Springs:
Well I am thinking about just buying some Eibachs, but I do not know how hard it is to put these bad boys on. Do I need to just take them to a shop? Or is it something I could do on my own?
Old 02-20-2011, 04:47 AM   #5
Without any idea as to your mechanical aptitude I couldn't tell you. A good set of spring compressors, the ability to find all the hidden screws to remove the trim in the trunk and the ability to turn a wrench and put things back how they were before is about all you need. Being careful with separating the springs from the dampers is the only part where you need to exercise care.... the stockers have more preload than the Eibach's so taking them off you need to use a spring compressor to compress them before taking off the hat.
Old 02-20-2011, 12:42 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
Just to add to what cre as said, you will need a set of spring compressors (as in pic below), mine where a set of cheap ones, the threads are just starting to strip. Having said that, I’ve used them on other vehicles more than a dozed times. Not a difficult job to do, the rear ones are the easiest. It’s only a question of removing the shocks. The front ones you will need to undo the top wishbone bolt, the wishbone will then be clear to gain accesses to removing the shock. You may find you will need a scaffold pipe on the end of your wrench to undo the wishbone bolt (mine where very tight) The only other restriction was the screen wash bottle (on the passenger side for LHD Supras) the bolt will just squeezes past it if your lucky.
Edit, Just one more thing: Always torque up the shock bolts with the vehicle on the ground (not jacked up)
The bottom rubber bush could distort otherwise.
Brake Warning Light on dash!... *D-Joker* MKIII Supra 6 08-28-2009 12:53 AM
Brake light failure... RNEMESiS42 MKIII Supra 17 08-10-2008 12:53 AM
Spoiler Brake Light Info Bill UK MKIII Supra 0 10-27-2006 10:06 PM
Hand Brake Light 88Supra Non-Generation Specific Questions 8 08-18-2006 01:35 PM
