Old 02-04-2011, 06:33 PM   #1
Supra Saiyan
Supra Saiyan's Avatar
Supra Saiyan is on a distinguished road
Default Best Cylinder Head Seal
I need to know what is the BEST Cylinder Head gasket sealer.. I used some crappy stuff and did a crappy job before sealing it up. Luckily 7mgte are built to withstand shithead moves like that. Sooo~ I want to make it right, or rather HAVE to make it right..
I need to know what sealer I should use that will last long..
I want to do this on Sunday..
Supra Saiyan is offline   Reply With Quote
Old 02-04-2011, 11:24 PM   #2
907mge
907mge's Avatar
I used permatex copper spray.
Old 02-05-2011, 08:40 AM   #3
Supra Saiyan
thanks
Old 02-05-2011, 09:31 PM   #4
El_supracabra
El_supracabra is on a distinguished road
ideally you shouldnt have to use any sealer, If the head and block are machined.....unfortunately most people dont have the desire/time/money to take their engines to the machine shop then deal with all of the "extras" that come with it.
So yeah, copper spray. just be careful to spray it on evenly and let it get tacky before torqueing it down. oh and make sure that ALL of the old gasket material is COMPLETELY scraped off, and use a good brake parts cleaner to remove ALL traces of oil from the head and block surfaces.
Good luck!
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
Old 02-05-2011, 10:57 PM   #5
907mge
907mge's Avatar
If you don't machine the head when it is needed then you are just asking for trouble. As well as cleaning the head and block surfaces is a must. The spray is just a good precaution to take which helps seal and improve heat transfer. It is most certainly not a cheap way to avoid the machine shop.
http://www.permatex.com/products/aut...ve_Sealant.htm
Old 02-06-2011, 01:10 AM   #6
El_supracabra
I never said it was a "cheap way to avoid the machine shop".
Cylinder head SuprAllen Non-Generation Specific Questions 1 06-24-2009 09:33 PM
torque settings for big end shells and cylinder head johnkarl MKIII Supra 4 11-03-2006 04:01 PM
Cylinder Head?? ZauggIt1 MKIII Supra 8 10-24-2006 01:51 AM
