Old 02-07-2011, 06:14 AM   #1
kcahrens
kcahrens is on a distinguished road
Default Ct26 turbo charger waste-gate weld?
I understand what the waste-gated does, It opens at idle /low rpms and controls the speed of the turbine (feel free to elaborate or correct my thoughts). It is to my understanding that if the waste gate were to be permanently (via weld) shut that the idle spool of the turbo would be greater therefore less spool up time. Is there any down side to this? There must be some reason to have a waste gate other than spooling the turbo at a lower rate during idle/low rpms. Would it effect the life/heath of the turbo or engine or an other parts?
88 Supra Tegra 7M-GTE Manual
Seattle, Washington (Granite Falls)
kcahrens is offline   Reply With Quote
Old 02-07-2011, 06:53 AM   #2
The other way around... it open as manifold pressure increases to slow the exducer so you don't exceed a given target. Keeping it closed and you'll over boost very frequently and risk THOROUGHLY trashing something (see: turbo and/or engine).
The ONLY gain you see in not letting the waste gate open is that you will see less smooth of a drop off as you reach the target boost and the gate opens completely... Usually this presents as a surge... not too good for things but not a killer...
There's really nothing to be gained from what we've discussed here.. you're better off leaving it all alone. Go read up some more and then read up on boost controllers.
ct26 turbo question dark91zc MKIII Supra 4 07-03-2005 08:14 AM
