Old 02-17-2011, 12:19 AM   #11
richitej909
richitej909's Avatar
richitej909 is on a distinguished road
Talking
glad i looked around im planning on converting my mk3 from auto to manual tranny as well
richitej909 is offline   Reply With Quote
Old 02-17-2011, 01:57 AM   #12
Originally Posted by Travis89Turbo View Post
The w58 (NA trans) will work but you have to use a na clutch with turbo flywheel. Which you will be way over powering a stock na clutch so id recommend upgrading.. stay away from ebay clutchs.. The r154 (turbo) trans is alot more robust and reliable under higher HP. But it uses a pull style clutch not a push type like the w58.
WTF?? Why would he use a R154 flywheel with a W58? Use the W58 flywheel... it's a tad smaller and lighter and there's no difference in contact area... besides, the W58's pressure plate won't fit the R154's flywheel as far as I remember.
I'm pretty sure all US supras have ABS.
No, most do not have it. It was an option only.
I'm pretty sure all you need to do is route the NSW through the clutch safety switch... it will operate just like a factory 5 speed as it prevents the circuit opening relay from closing unless the clutch is pressed.
http://www.cygnusx1.net/Supra/Librar...px?S=Main&P=46
Old 02-17-2011, 02:15 AM   #13
Travis89Turbo
Travis89Turbo's Avatar
Originally Posted by cre[B
;92499]WTF?? Why would he use a R154 flywheel with a W58? Use the W58 flywheel... it's a tad smaller and lighter and there's no difference in contact area... besides, the W58's pressure plate won't fit the R154's flywheel as far as I remember.
Shit. Your right about the flywheels. I did some digging deep into my notes (from 7 yrs ago) and it is the w58 flywheel. I apologize
And the ABS thing is crazy! I have had 4 mkiii supras one na and 3 turbos, all had abs.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Speed Sensor Problem (Auto) GettaRobo MKIII Supra 8 04-26-2010 12:27 PM
New to MK4 (Auto TT to 5-or 6 Speed TT?) Mattz32 MKIV Supra 2 11-01-2008 06:25 PM
5 speed harness on auto? go.stfu MKIII Supra 2 10-09-2007 01:57 AM
Auto or 6 speed??? 2JZEFINI-17 MKIV Supra 13 09-11-2006 11:19 AM
