Old 02-12-2011, 01:26 PM   #1
jtown125
jtown125 is on a distinguished road
Default I have a crazy idea??
I have a 7mgte ready to be rebuilt n put in a car. I also have an 80 Turbo Trans am body sitting in the garage as well...
I have seen 350 put into supra's...
350 n 403, 301, 400, and etc....they have the same motor mounts....
I also have a 403 that needs to be rebuilt....
I would like to put the 7mgte engine in the turbo trans am....much like you saw the mustang on Tokyo Drift...
And then put the 403, or the 301 with turbo in the supra...
now someone plz tell me how stupid that sounds....
89 mkIII turbo supra stick black w/ maroon interior!!!
jtown125 is offline   Reply With Quote
Old 02-12-2011, 04:10 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
7mgte in the trans am would be pretty sick! But what year trans am turbo is it?
I honestly don't think you should put a v8 in the supra. The thought of it makes me want to but it can be done! There is a guy on this board that has a real clean 350 swapped in ill try to find the link.
Here it is..
http://www.toyota-supra.info/forums/...-yes-i-am.html
I suggest a jz engine though and I always will. For both vehicles if your gonna go through the trouble of swapping an engine get one that's gonna work without having to tear it apart. Not to mention faster!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 02-12-2011, 11:59 PM   #3
jtown125
I have never experienced a jz engine...but I would love to get the chance too. And i know how hard my 7mgte engine pulls so if you say the jz is faster im just so curious
Either way it would def be a challenge.
I took some measurements earlier, and it will fit, it will be EXTREMELY TIGHT though.
The less I would have to do with the ecu swap would make me happier. Running the main harness and setting up the ecu will be the hardest thing to do. Besides getting the motor mounts welded on.
Tags
trans am spura 7mgte 301
New Swap Idea?????? oldeskewltoy Non-Generation Specific Questions 0 06-03-2008 07:11 PM
My friends turbo idea RussianMK3 Off Topic Forum 4 01-16-2008 06:38 AM
wierd and crazy idea but i dont know if it is possible Jeff_5_7 MKIII Supra 1 08-18-2007 05:52 PM
my supra acting CRAZY help!! mjmendoza MKIII Supra 7 05-09-2007 10:59 PM
damn air going crazy again sd88supra MKIII Supra 1 02-23-2006 04:12 PM
