Old 02-15-2011, 04:54 AM   #1
spunkenhimer
spunkenhimer's Avatar
spunkenhimer is on a distinguished road
Default 88 supra still with problems 7MGE
OK so here is the just. I blew a head gasket and replaced it. put it all back together and now the engine stays cool but i keep getting cool air out of the heating system in the car itself.
The car doesn't want to stay at a proper idle and when i try to rev it to about 2000rpm it starts to fluctuate from 1200rpm to 2000rpm over and over unless i give it more gas and get it to about 3000rpm and it'll stay there. If i let off the gass it'll drop below 1000rpm and eventually die.
Might have 2 seperate problems here but i don't know. the heating in the car worked before i did the gasket replacement and i swear i checked my lines 4 even 5 times before i went to hook it all up.
one last thing after i thought i had it finished i took it to a local gas station and got some gas but on the way back my throttle got stuck mid shift and went up too like 7000rpm and i had to turn the car off at that high of an rpm and stop and get out and fix it thats cause i didn't screw down the throttle linkage down all the way. that happened in between the car cutting off on its own.
Please help me i need my Berniece back she means so much to me.
spunkenhimer is offline   Reply With Quote
Old 02-16-2011, 02:06 AM   #2
spunkenhimer
Had someone send new this ( http://www.toyota-supra.info/forums/...e-problem.html ) but my car isnt getting hot on idle just sounding hard and cutting off. My car got hot cause I didn't clamp every thing down at first and one of the hoses poped off due to my throttle getting stuck. (something else I didn't tighten down all the way.)
Old 02-16-2011, 08:15 AM   #3
ahruizguerra
ahruizguerra is on a distinguished road
Suggestions:
  1. Check the MAF sensor connector. Sometimes it looks like it is hoop up right; but inside terminals might be dirty.
  2. Check The TPS connector
  3. Check the IDLE valve connector, do you hear any sound out of the idle valve as soon as you turn off your car????
  4. Check that the fuel pressure regulator and fuel pump are working correctly.
Do you have the check engine light on????
ahruizguerra is offline   Reply With Quote
Old 02-16-2011, 02:36 PM   #4
spunkenhimer
no check engine light
thanks i'll check and see where those are.
Old 02-17-2011, 12:53 AM   #5
spunkenhimer
ok now i go to crank it up and it wont get past 500rpm and when i try and gas it it wont throttle or rev up at all. could the fuel pump or fuel filter be a problem?
Old 02-17-2011, 01:46 AM   #6
Your car doesn't have a MAF... it has a VAFM and the GTE's have a KVAFM A huge difference between all three.
Check for diagnostic codes; Very few or the error codes will turn on the check engine light.
Fuel pump and filter are possibilities, but there are many others too. Start with checking the codes and post back.
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
Here'e the info on testing the VAFM (you may refer to it as an AFM if you like, both types used in the MKIII are AFM type devices).
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=94
Old 02-19-2011, 04:09 AM   #7
spunkenhimer
the check engine light doesn't come on at all would it come on when i turn the car on with the wires connected?
oh and the fuel pump isn't the problem fuel works fine. something with the vacuum lines or the timing...or god help me compression if its compression i'm just putting the damn car up for a few weeks getting me a honda and saving till i can buy a gte or a 2jz or something of the sort.
Old 02-19-2011, 04:13 AM   #8
The Check Engine light should ALWAYS come on when the key is turned to the ON position but not started; If it doesn't the bulb's burned out or there's a fault in the ECU.
If there are no diagnostic codes the Check Engine light will flash continuously at a high speed.
Old 02-19-2011, 04:17 AM   #9
spunkenhimer
oh ok will get that done first thing in the morning was gonna do it today but didn't have enough time cause i had to work.
Old 02-19-2011, 11:05 PM   #10
spunkenhimer
41 and 51 are the diagnostic codes my check engine light show to me. saying my throttle position sensor is the problem but i don't see how cause i checked that last night and it didn't seem to be the problem..idk. can anyone explain.
1988 supra 7mge engine blown what to do? 88supra7mge MKIII Supra 6 08-23-2010 05:22 PM
Supra 87 7mge CanadianBak'inSupra MKIII Supra 6 10-19-2009 12:30 PM
Want to buy a Supra, though having some problems finding one. Cypherbku MKIV Supra 3 03-03-2009 01:45 AM
86 supra problems dom747 Non-Generation Specific Questions 1 11-06-2006 03:52 PM
