Old 02-17-2011, 06:09 AM   #11
ahruizguerra
ahruizguerra is on a distinguished road
Default ...
..I actually remove the oil pan twice, and it didn't took me that long, only 2 hours. I have to because the first time i use the crappy Fel-pro gasket and it stared to lick after 3,000 miles. Of you use a tower jack to hold the transmission, loose (not disconnect) the brake lines, and disconnect the structs from the lower control arm, you can easly drop the front suspension enough so you can work with plenty of space.
ahruizguerra is offline   Reply With Quote
Old 02-17-2011, 05:38 PM   #12
These oil pans don't use gaskets; They're not designed for it. You're just begging for trouble if you put one in there.
Unless you've got a lift, working on the engine from under it is miserable... I've done it too.
Citric Acid? To clean Catalytic Converters? For real? ravenmaster Non-Generation Specific Questions 11 02-13-2018 06:23 AM
looking for CLEAN 1j, 2j swapped targa mk3 brandonmbyers Buy/Sell Cars 0 02-01-2011 07:04 PM
What is a good way to clean out the engine bay? D_Train MKIII Supra 21 05-19-2007 07:11 PM
