Old 04-21-2011, 02:51 PM   #21
01010011
01010011's Avatar
01010011 is on a distinguished road
Unhappy oki dokie WTF
changed the oil pan and oil pump from the donor 7M got the engine to go smoothly into the chassis and began hooking everything up top to bottom left to right filled all my fluids etc but regardless of how much i check and re check all the wiring and ground when i went to try and light it up the car gets no power to anything what so ever... i've checked the wires try arranging the grounded wires in several different locations but every time i attach the battery to the posi terminal the fuse box makes a clicking noise im assuming thats not a bad thing so i inspect the fuses and non appear to be blown i have no way of testing the head fuse nor the main fuse but when i do this i have a check engine light which is the only thing that comes on nothing else gets power so i put the key in the ignition and try to turn it and it just dings at me ive been working on this thing endlessly so i can have 1 running car please help >_<
oh and i have 1 plug from the ecu side which is white with two a few cables cant figure out where that goes and engine side i have 2 plugs that i have no idea where those go either one is green with 4 ports inside and one is an orange color with 2 plugs inside here are some pics maybe this is part of my problem??
Here are some pictures and video
http://img.photobucket.com/albums/v2...a/IMAG0036.jpg
http://img.photobucket.com/albums/v2...a/IMAG0038.jpg
http://img.photobucket.com/albums/v2...a/IMAG0039.jpg
http://img.photobucket.com/albums/v2...a/IMAG0040.jpg
http://img.photobucket.com/albums/v2...a/IMAG0041.jpg
http://img.photobucket.com/albums/v2...a/IMAG0042.jpg
http://smg.photobucket.com/albums/v2...=VIDEO0016.mp4
http://smg.photobucket.com/albums/v2...=VIDEO0017.mp4
um what was i saying? 0_0..
01010011 is offline   Reply With Quote
Old 04-21-2011, 10:00 PM   #22
87hilux7mge
87hilux7mge's Avatar
well...the clips you show look like a cold start injector clip (red) and a starter connection possibly (blue) :/. the two 7m motors i got had different connections, 1 from an 88 jdm supra and one from a 90 cressida.
u could try and go to sears auto center and see if they are nice enough to print you out a diagram of the ECU wiring from alldata. the full set at my house, but no computer there. if i get it back to town, i can upload them prolly.
basically u just have to trace your wires.. everyone should learn to label wires and tag and bag parts, saves alot of time. i never did for the longest time and was fine without it, until i got two projects goin at once for an extended period of time and then i really got lost.
b4 that tho, i took apart my whole 22r and rebuilt it, no manual, no parts baggies, no labeling, in about 2 weeks. no extra bolts or parts left over, except what i intentionally removed.
with my build, i have EVERYTHING in a well labeled bag and all my wires in the engine bay labeled correctly. as well as the supra and truck manuals always on my bench.
sorry went off on a rant there...neway, check you wiring, u couldve missed a starter connection or have a bad power/ground connection somewhere. make sure your batt is fully charged too.
Tags
build, restoration
Need some serious help choosing a car for a new project. BAN WS6 Non-Generation Specific Questions 0 05-07-2009 04:08 AM
Help me with my SSTS project! Da1spa247 Non-Generation Specific Questions 0 09-25-2007 08:21 PM
