#31 | |
![]() Quote:
http://www.perfectengine.com/Toyota_...ROC-EK943M.htm |
#32 | |
![]() Quote:
You da man. Ya for sure I was going to have the block done up and machined.its awesome its so cheap. Fuck me in... If I have to replace the block. Though I have done cheap options. |
#33 |
Mechanic found a good amount of the engine flush in the oil. Soooo~ he said that is really bad.. Thx Tiffy Loo..
What do you think..? |
#34 | |
![]() Quote:
Can a Engine Oil Flush Cause Damage to the Engine? There are a lot of opinions as to whether or not an engine oil flush can cause damage to the vehicles engine. Since today’s modern engines have tighter oil passages than the engines of old, there’s a possibility that sludge deposits could break up and become lodged in oil passages. This could decrease the flow of engine oil to vital engine components and cause damage to those components. Another possibility is that particles from the engine oil flush could block the pick up screen to the engine oil pump. This could cause a loss of oil pressure that could result in engine damage. If an engine oil flush is performed, ask the service advisor if there are any warranties or guarantees against engine damage. If there is a warranty that comes with an engine flush service, get it in writing, don’t take a service advisors word for it. If the engine oil and filter are religiously replaced at the manufacturers recommended intervals, there shouldn’t be a need to have the vehicles engine oil flushed. From: http://www.suite101.com/content/engi...d-cons-a137008 |
#35 |
Engine flush cleans the sludge out and it also thins out the oil. Maybe a piece of sludge got stuck because they didnt run it long enough. Which blocked the oil from getting to the parts. Then u said he found alot of motor flush in the oil then your oil was real thin then and it can't lube the parts good. Are you sure they even changed the oil. That's why I do my oil changes everyone is out to get ur money now days.
#36 | |
![]() Quote:
Thread Tools | |
Display Modes | |
'89 Engine Knock! Need advice! | BrianSupra89 | MKIII Supra | 3 | 09-08-2010 12:00 AM |
Starting isssues and spark knock Q's | spudz29212MKIII | MKIII Supra | 65 | 05-30-2008 06:44 PM |
Engine knock @ 1700-2300 | rstutler | MKIII Supra | 8 | 03-07-2008 07:36 PM |
problem seperating engine from manual tranny | Gengus | MKIII Supra | 7 | 01-29-2008 12:10 AM |
