Old 03-26-2011, 11:07 PM   #91
ochowdero
what are all of these?
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Old 03-27-2011, 12:00 AM   #92
Travis89Turbo
Travis89Turbo's Avatar
The plug is your reverse switch. and the other threaded hole on pass. Side by the tail piece is for the speedo
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 03-28-2011, 03:30 AM   #93
crazysuprafinatic18
crazysuprafinatic18's Avatar
crazysuprafinatic18 is on a distinguished road
Idk if you have already decided to do whatever it is you were going to do. I think the easiest thing to do is to get the car up on four jack stands, makes things a lot simpler. Then get the jack under the tranny and take the bolts off and the couple connections and that's about it for taking it off.
crazysuprafinatic18 is offline   Reply With Quote
Old 03-28-2011, 03:31 AM   #94
crazysuprafinatic18
Ooops maybe should have kept going through the post. Sorry I was a little late aha
Old 03-28-2011, 04:15 AM   #95
ochowdero
so when i do the swap the speedo cable screws on and the reverse lights are the only to things i need for the swap? is there any other cables or plugs?
i really want turbo
Old 03-28-2011, 07:23 AM   #96
The additional room is very nice but this can be a lethal suggestion unless additional efforts are in place. I recommend placing the car's wheels or another different under the frame and floorboard if you don't have wheels to use then put each on top of two parallel pieces of 2x4. Try to get them tall enough to leave only and in or two of clearance on top.
Old 03-28-2011, 08:28 AM   #97
ochowdero
i use cinder blocks :P
i really want turbo
Old 03-28-2011, 07:48 PM   #98
Travis89Turbo
Other then bypassing the park switch that's it!
stock 2jzge
Old 03-28-2011, 08:40 PM   #99
ochowdero
how do i bypass?
and when i do, do i still step on the clutch to start it?
i really want turbo
Old 03-29-2011, 01:15 AM   #100
Rims are less likely to tip.... or crumble. :P With out a lift I'm paranoid.
86.5 auto transmission removal HELP!!! elmer MKIII FAQ 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Need transmission removal help ASAP FunWheelDrive MKIII Supra 2 03-23-2008 12:35 AM
